Configure Link Debounce for ports to hold the connection path until the carrier side switchover is complete.
enable
configure terminal
interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
link-debounce <0-300000>
show interfaces gigabitEthernet link-debounce [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Configure the Link Debounce timer on port 1/2 to 300000 milliseconds.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitEthernet 1/2 Switch:1(config-if)#link-debounce 300000
Display the Link Debounce configuration for ports 1/1 through 1/4.
Switch:1>enable
Switch:1#show interfaces gigabitEthernet link-debounce 1/1-1/4
Port link debounce
PORT LINK-DEBOUNCE LINK-DEBOUNCE DEBOUNCE DEBOUNCE
NUM STATUS TIMER MILLISECONDS COUNT SUCCEEDED
1/1 Enable 1500 0 0
1/2 Enable 300000 0 0
1/3 Disable -- 0 0
1/4 Enable 4000 0 0
